跳转到主内容
Logitech Harmony 1100 Logic Board Replacement
你所需要的
  1. Logitech Harmony 1100 Logic Board Replacement, How to Open Logitech Harmony 1100: 步骤 1 中的图像 1,2 Logitech Harmony 1100 Logic Board Replacement, How to Open Logitech Harmony 1100: 步骤 1 中的图像 2,2
    • Remove the battery cover by pushing down on the circled areas and pushing outward.
    • Remove the battery by lifting up the battery on the corner exposed by the indent in the case
  2. Logitech Harmony 1100 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Use a J0 screwdriver head
    • Remove the 3 screws from battery compartment
  3. Logitech Harmony 1100 Logic Board Replacement: 步骤 3 中的图像 1,2 Logitech Harmony 1100 Logic Board Replacement: 步骤 3 中的图像 2,2
    • Open the connector port on the side.
    • Remove screw with a PH00 screwdriver head.
  4. Logitech Harmony 1100 Logic Board Replacement: 步骤 4 中的图像 1,3 Logitech Harmony 1100 Logic Board Replacement: 步骤 4 中的图像 2,3 Logitech Harmony 1100 Logic Board Replacement: 步骤 4 中的图像 3,3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • The plastic connector door will fall off. It will need to be put back upon reassembly.
  5. Logitech Harmony 1100 Logic Board Replacement, Screen: 步骤 5 中的图像 1,1
    • Pop out the plastic screen backing on front of device.
    • Loosen the screen backing by pushing back on the plastic clips that hold the screen backing in place.
  6. Logitech Harmony 1100 Logic Board Replacement: 步骤 6 中的图像 1,2 Logitech Harmony 1100 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Use the PH00 Phillips head from the iFixit Tool Kit to remove the 3 screws from the circuit on the back half of the device.
    • Use the edge of the larger circuit board to flip the board over to the left.
    • The connector port in the top right corner may make removal difficult. Lift the logic board above the screw ports, and the connector port should slide out easily.
  7. Logitech Harmony 1100 Logic Board Replacement: 步骤 7 中的图像 1,2 Logitech Harmony 1100 Logic Board Replacement: 步骤 7 中的图像 2,2
    • Find the wire that attaches to the screen.
    • Push the dark grey bar that is used to lock the screen in place, outward from the beige bar to disconnect it.
    • Remove the screen wire.
  8. Logitech Harmony 1100 Logic Board Replacement, Logic Board: 步骤 8 中的图像 1,2 Logitech Harmony 1100 Logic Board Replacement, Logic Board: 步骤 8 中的图像 2,2
    • Push grey bar away from the beige bar
    • Remove button tab wire from logic board
  9. Logitech Harmony 1100 Logic Board Replacement: 步骤 9 中的图像 1,3 Logitech Harmony 1100 Logic Board Replacement: 步骤 9 中的图像 2,3 Logitech Harmony 1100 Logic Board Replacement: 步骤 9 中的图像 3,3
    • Lift on back of gold tab to unsecure positive and negative wires from device
    • Pull the gold buttons in towards the center of the device to detach logic board from case
终点
Chris Slack
于02/11/16注册
10 声望
撰写一个指南
团队
Ohio State, Team 1-5, Burgess Spring 2016 Ohio State, Team 1-5, Burgess Spring 2016 的会员
OSU-BURGESS-S16S1G5
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 995
