跳转到主内容
加入维修社区 - 创建账户
Logitech Gamepad F310 Buttons Replacement
你所需要的
  1. Logitech Gamepad F310 Buttons Replacement, Case: 步骤 1 中的图像 1,2 Logitech Gamepad F310 Buttons Replacement, Case: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    询问修复机器人
    添加评论
  2. Logitech Gamepad F310 Buttons Replacement: 步骤 2 中的图像 1,2 Logitech Gamepad F310 Buttons Replacement: 步骤 2 中的图像 2,2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    添加评论
  3. Logitech Gamepad F310 Buttons Replacement: 步骤 3 中的图像 1,1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    询问修复机器人
    添加评论
  4. Logitech Gamepad F310 Buttons Replacement, Buttons: 步骤 4 中的图像 1,2 Logitech Gamepad F310 Buttons Replacement, Buttons: 步骤 4 中的图像 2,2
    • Remove any buttons that need replacement.
    • The buttons sit loosely in the front of the controller, so flipping the front over will drop all of the buttons out.
    询问修复机器人
    添加评论
结论
You're all finished! To reassemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
1指南评论
Any idea where I can get the d-pad rubber dome replacement part?
Anggoro Arif Junianto - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 73
总计 1,399
