简介
Use this guide to remove and replace a keycap on the Logitech G915 TKL keyboard. A keycap may need to be replaced if it's loose and not registering inputs properly, or simply broken for one reason or another. You may also need to remove or replace a keycap to fix other issues such as a broken keyswitch or double key presses.
No special tools or skills are required to complete this repair procedure.
你所需要的
Insert a flat tool underneath the top of the keycap or use your keycap puller to remove the keycap.
You may need to remove other keycaps to reach the keycap you wish to remove.
You've successfully removed and replaced a keycap on your Logitech G915 TKL keyboard.
