跳转到主内容
Logitech G915 TKL G1-G8 Key Replacement
你所需要的
  1. Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: 步骤 1 中的图像 1,3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: 步骤 1 中的图像 2,3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: 步骤 1 中的图像 3,3
    • Remove all the keycaps.
    • While it can be done barehanded, use of a flat tool to remove the keycaps or use a keycap puller is recommended to prevent damage.
  2. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the front: 步骤 2 中的图像 1,1
    • Unscrew the front 2mm #00 Phillips screws found here.
  3. Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: 步骤 3 中的图像 1,3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: 步骤 3 中的图像 2,3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: 步骤 3 中的图像 3,3
    • Remove the battery.
    • This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
  4. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the back: 步骤 4 中的图像 1,1
    • Remove the remaining 2mm #00 Phillips back screws.
    • 3 screws are hidden under the rubber rests of the keyboard.
  5. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the motherboard: 步骤 5 中的图像 1,1
    • Remove the 2mm #00 Phillips motherboard screws.
    • The G1-G8 keys are held in place by the motherboard itself. Once the motherboard is detached, they can be easily removed and replaced by hand.
结论
另外一个人完成了本指南。
Brandon Souza
于03/13/23注册
136 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-6, Petersen Spring 2023 UMass Dartmouth, Team 3-6, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G6
4 名成员
创作了14篇指南
2条评论
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
Magnus - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 45
过去 30 天: 211
总计 2,476
