跳转到主内容
Logitech G915 TKL Battery Replacement
你所需要的
  1. Logitech G915 TKL Battery Replacement, Battery: 步骤 1 中的图像 1,2 Logitech G915 TKL Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5 mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  2. Logitech G915 TKL Battery Replacement: 步骤 2 中的图像 1,2 Logitech G915 TKL Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully unplug the battery connector, pulling away the plastic part using your fingers.
  3. Logitech G915 TKL Battery Replacement: 步骤 3 中的图像 1,1
    • Put in your replacement battery.
结论
另外一个人完成了本指南。
Ethan Bedard
于03/13/23注册
485 声望
创作了3篇指南
团队
UMass Dartmouth, Team 3-6, Petersen Spring 2023 UMass Dartmouth, Team 3-6, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G6
4 名成员
创作了14篇指南
3条评论
where do you buy the battery?
luke dollard - 回复
This guide is great, but mentioning what kind of battery to purchase for the keyboard would make it infinitely better...
Darbii Rue - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 167
总计 2,521
