跳转到主内容
Logitech G733 Volume Scroll Wheel Replacement
你所需要的
  1. Logitech G733 Volume Scroll Wheel Replacement, Volume Scroll Wheel: 步骤 1 中的图像 1,1
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
  2. Logitech G733 Volume Scroll Wheel Replacement: 步骤 2 中的图像 1,2 Logitech G733 Volume Scroll Wheel Replacement: 步骤 2 中的图像 2,2
    • Remove the four screws securing the speaker housing using the T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
  3. Logitech G733 Volume Scroll Wheel Replacement: 步骤 3 中的图像 1,3 Logitech G733 Volume Scroll Wheel Replacement: 步骤 3 中的图像 2,3 Logitech G733 Volume Scroll Wheel Replacement: 步骤 3 中的图像 3,3
    • The plastic cover should be lose now and you should be able to pull it back to reveal the circuit board inside.
    • Unscrew the screw on the bottom right-hand side of the headphone using the #000 Phillips Screwdriver.
    • Finally, use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
    • The scroll wheel may fly out when you pop the circuit board out.
  4. Logitech G733 Volume Scroll Wheel Replacement: 步骤 4 中的图像 1,2 Logitech G733 Volume Scroll Wheel Replacement: 步骤 4 中的图像 2,2
    • Pull the volume wheel directly out.
    • Place the new scroll wheel in by lining up the two flat surfaces on the connectors.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 41
过去 30 天: 186
总计 2,125
