跳转到主内容
Logitech G710+ Disassembly
你所需要的
  1. Logitech G710+ Disassembly, Body: 步骤 1 中的图像 1,1
    • Remove 14 Phillips screws on the bottom of the kayboard.
    • Use a plastic tool to release the clips holding the case together.
    • There are two hidden clips above the left and right arrow keys.
    • Gently pry the two halves of the case apart.
    • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
  2. Logitech G710+ Disassembly, Mother board: 步骤 2 中的图像 1,3 Logitech G710+ Disassembly, Mother board: 步骤 2 中的图像 2,3 Logitech G710+ Disassembly, Mother board: 步骤 2 中的图像 3,3
    • Unscrew the one screw holding on the ground and pull out the cables.
    • A good way of getting the cables out is by putting a screwdriver right there and twisting.
    • Unscrew this screw
  3. Logitech G710+ Disassembly, Scroll Wheel: 步骤 3 中的图像 1,1
    • The light thing comes out with a wiggle.
    • The scroll wheel on the other is harder because you have to melt or brake the supports off.
    • Then you have to get the wheel out which comes out with a very gentle wiggle.
  4. Logitech G710+ Disassembly, Pads: 步骤 4 中的图像 1,1
    • You can then take off the little pads
结论
6等其他人完成本指南。
Jackson Poer
于04/08/17注册
671 声望
创作了2篇指南
2条评论
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - 回复
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 94
总计 7,788
