跳转到主内容
Logitech G602 Side Motherboard Replacement
你所需要的
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: 步骤 1 中的图像 1,1
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: 步骤 3 中的图像 1,2 Logitech G602 Side Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: 步骤 5 中的图像 1,2 Logitech G602 Side Motherboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
结论
另外一个人完成了本指南。
一条评论
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 44
总计 3,704
