跳转到主内容
Logitech G602 Scroll Wheel Replacement
你所需要的
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: 步骤 1 中的图像 1,1
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: 步骤 3 中的图像 1,2 Logitech G602 Scroll Wheel Replacement: 步骤 3 中的图像 2,2
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: 步骤 4 中的图像 1,1
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
    No idea what this is supposed to mean. The name of this guide is "replacement". The final instruction here is to "test the wheel's usability"?
    Felix - 回复
结论
8等其他人完成本指南。
2条评论
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - 回复
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 107
总计 7,890
