跳转到主内容
Logitech G602 Scroll Wheel Replacement
你所需要的
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: 步骤 1 中的图像 1,1
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: 步骤 3 中的图像 1,2 Logitech G602 Scroll Wheel Replacement: 步骤 3 中的图像 2,2
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: 步骤 4 中的图像 1,1
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
结论
9等其他人完成本指南。
4指南评论
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - 回复
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - 回复
"Logitech G602 Scroll Wheel Replacement" - completely misleading title. Thanks for wasting people's time.
Myshka - 回复
Merci pour les recommandations. Elles m'ont permis de voir qu'il y avait un fil dessoudé. ça m'aurait bien gêné d'en racheter une autre.
Didielus - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 80
总计 9,858
