跳转到主内容
Logitech G432 Volume Button Replacement
你所需要的
  1. Logitech G432 Volume Button Replacement, Earpad Cushions: 步骤 1 中的图像 1,2 Logitech G432 Volume Button Replacement, Earpad Cushions: 步骤 1 中的图像 2,2
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Volume Button Replacement, Volume Button: 步骤 2 中的图像 1,3 Logitech G432 Volume Button Replacement, Volume Button: 步骤 2 中的图像 2,3 Logitech G432 Volume Button Replacement, Volume Button: 步骤 2 中的图像 3,3
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Volume Button Replacement: 步骤 3 中的图像 1,1
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Volume Button Replacement: 步骤 4 中的图像 1,2 Logitech G432 Volume Button Replacement: 步骤 4 中的图像 2,2
    • To adjust and fix the volume button, use a Phillips #0 screwdriver to tighten, loosen, or remove the 1.0 mm screw located on the left side.
结论
Lara Vasquez
于02/24/23注册
412 声望
创作了4篇指南
团队
Marist, Team 1-2, Chaterdon Spring 2023 Marist, Team 1-2, Chaterdon Spring 2023 的会员
MARS-CHATERDON-S23S1G2
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 35
总计 968
