跳转到主内容
加入维修社区 - 创建账户
Logitech G400s Scroll Wheel Replacement
你所需要的
  1. Logitech G400s Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,1
    • Use a flathead screwdriver or your fingernail to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Scroll Wheel Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Scroll Wheel Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Scroll Wheel Replacement: 步骤 4 中的图像 1,1
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Scroll Wheel Replacement: 步骤 5 中的图像 1,1
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Scroll Wheel Replacement: 步骤 6 中的图像 1,1
    • Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
结论
2等其他人完成本指南。
Max Evans
于09/28/16注册
433 声望
创作了3篇指南
团队
USF Tampa, Team 16-7, Eyestone Fall 2016 USF Tampa, Team 16-7, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G7
1 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 4,277
