跳转到主内容
Logitech G29 Driving Force Share/Options/PS Buttons Replacement
你所需要的
  1. Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: 步骤 1 中的图像 1,3 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: 步骤 1 中的图像 2,3 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: 步骤 1 中的图像 3,3
    • Remove the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. These screws have an outer diameter of 8.40mm with a length of 26mm.
    • Once the center cap is removed, detach the face of the wheel from the stand. Before removing it completely, disconnect the 7 pin white cable running into the base of the wheel, and place aside.
  2. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 步骤 2 中的图像 1,1
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit J0.
  3. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove Daughterboard using bit J0
    • Remove the 2 small black screws diameter 3.41mmlength 5mm from the small PCB using the J00 bit. Once the small PCB is unscrewed set the whole board aside. This will expose a black housing that all three buttons are attached to. This was removed using the same bit and screws of the same diameter.
  4. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 步骤 4 中的图像 1,1
    • A black housing that all three buttons are attached to will be seen. This was removed using the same bit and screws of the same diameter.
  5. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: 步骤 5 中的图像 1,1
    • Pick up black housing using fingers (universal size) and remove.
结论
Ben varner
于11/08/23注册
400 声望
创作了3篇指南
团队
IUPUI, Team 1-3, Harley Fall 2023 IUPUI, Team 1-3, Harley Fall 2023 的会员
IUPUI-HARLEY-F23S1G3
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 48
总计 1,060
