简介
This guide will explain how to replace the red dial on the Logitech G29 wheel. If the dial is malfunctioning, taking it apart could expose potential problems and reveal viable fixes. The process is not difficult and can be completed with little teardown of the product.
你所需要的
Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
在这个步骤中使用的工具:Tweezers$4.99
Press in the 3 red tabs located on the inside black housing of the dial. Using the medium sized tweezers, push the black center button out to reveal 3 small black screws.
Using the same bit as earlier (bit Ph #00), remove the three (3.32mm diameter 5mm length) screws to release the red dial.
另外一个人完成了本指南。
