跳转到主内容
Logitech G29 Driving Force Paddle Assembly Replacement
你所需要的
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: 步骤 1 中的图像 1,1
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
  2. Logitech G29 Driving Force Paddle Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Paddle Assembly Replacement: 步骤 3 中的图像 1,1
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
  4. Logitech G29 Driving Force Paddle Assembly Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the three 30 mm screws that are behind the steering wheel.
  5. Logitech G29 Driving Force Paddle Assembly Replacement: 步骤 5 中的图像 1,1
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 45
过去 30 天: 176
总计 6,884
