跳转到主内容
Logitech G29 Driving Force Force-Feedback Motor Replacement
你所需要的
  1. Logitech G29 Driving Force Force-Feedback Motor Replacement, Force-Feedback Motor: 步骤 1 中的图像 1,1
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
  2. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 3 中的图像 1,1
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
  4. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 4 中的图像 1,2 Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 4 中的图像 2,2
    • Using the #2 Phillips head screwdriver remove the three 30mm long screws that are behind the steering wheel.
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
  5. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the eight 15.9mm long silver screws on the bottom of the base of the wheel with a Phillips #1 screwdriver. (2 not circled covered by clamps in image)
  6. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 6 中的图像 1,1
    • Now remove the four 7.3mm long silver screws from the motherboard using a Phillips #2 screwdriver.
    • Then, carefully remove the seven plastic connectors from the motherboard. Make sure to avoid pulling by the wires and to only pull on the plastic
  7. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 7 中的图像 1,1
    • Remove the two black screws using a Phillips #2 screwdriver.
  8. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the four 12 mm screws with the Phillips #1 screwdriver.
  9. Logitech G29 Driving Force Force-Feedback Motor Replacement: 步骤 9 中的图像 1,1
    • Now that the complete driving assembly is out you can replace it as needed.
结论
7等其他人完成本指南。
4指南评论
how much is this part
glenn castillo - 回复
where do u get repayment parts ?
callum smith - 回复
Where can we find some replacments parts ?
super miaoumix - 回复
I’d like to disconnect those two motors because at night, when my family is sleeping, they make a lot of noise and I really don’t want to wake anyone up.
Is it possible to open up the G29, cut or unplug those motor cables, and still have everything else work properly?
David Martinez - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 131
过去 30 天: 631
总计 16,333
