跳转到主内容
加入维修社区 - 创建账户
Logitech G29 Driving Force Buttons Replacement
你所需要的
  1. Logitech G29 Driving Force Buttons Replacement, Buttons: 步骤 1 中的图像 1,3 Logitech G29 Driving Force Buttons Replacement, Buttons: 步骤 1 中的图像 2,3 Logitech G29 Driving Force Buttons Replacement, Buttons: 步骤 1 中的图像 3,3
    • Remove the six black screws holding the Playstation center cap using the Hex 4.0 bit.
    • The outer diameter of these screws are 8.40mm with a length of 26mm.
    • The wheel is still attached the base via a bundled cable-connector.
  2. Logitech G29 Driving Force Buttons Replacement: 步骤 2 中的图像 1,3 Logitech G29 Driving Force Buttons Replacement: 步骤 2 中的图像 2,3 Logitech G29 Driving Force Buttons Replacement: 步骤 2 中的图像 3,3
    • Gently lift the faceplate and wheel off the stand.
    • Pull the white 7-pin cable connector from the wheel PCB.
    • Use a spudger or plastic opening tool to help free the connector at its base. Do not pull on the wires.
  3. Logitech G29 Driving Force Buttons Replacement: 步骤 3 中的图像 1,2 Logitech G29 Driving Force Buttons Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the seven 8 mm silver screws that secure the main wheel PCB.
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw from the Share/Options/PlayStation button PCB.
  4. Logitech G29 Driving Force Buttons Replacement: 步骤 4 中的图像 1,3 Logitech G29 Driving Force Buttons Replacement: 步骤 4 中的图像 2,3 Logitech G29 Driving Force Buttons Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    $3.99
    • Once the PCB is out, the triangle, square, circle, x button will be exposed. Use the angled tweezers to remove all four buttons.
    • These buttons are keyed to where only a certain key will fit in a certain spot.
  5. Logitech G29 Driving Force Buttons Replacement: 步骤 5 中的图像 1,1
    • Once the PCB is out, the D-PAD will fall out as well. Use the angled tweezers to remove the D-PAD.
    • This is also keyed to where it can only fit in a certain direction.
  6. Logitech G29 Driving Force Buttons Replacement: 步骤 6 中的图像 1,3 Logitech G29 Driving Force Buttons Replacement: 步骤 6 中的图像 2,3 Logitech G29 Driving Force Buttons Replacement: 步骤 6 中的图像 3,3
    • Remove the four black 5 mm screws holding the four buttons in place using a Phillips #00 screwdriver. These are located directly under the buttons.
    • The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
  7. Logitech G29 Driving Force Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the four black screws holding the four buttons in place using a Phillips #00 screwdriver. These are located directly under the buttons. The whole housing is not required to come out since only the blue buttons need to come out. Once the screws are removed the buttons will fall out.
结论
Ben varner
于11/08/23注册
400 声望
创作了3篇指南
团队
IUPUI, Team 1-3, Harley Fall 2023 IUPUI, Team 1-3, Harley Fall 2023 的会员
IUPUI-HARLEY-F23S1G3
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 54
过去 30 天: 198
总计 4,015
