跳转到主内容
加入维修社区 - 创建账户
Logitech G1 Optical Mouse Scroll Wheel Replacement
你所需要的
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,1
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 2 中的图像 1,2 Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 2 中的图像 2,2
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 3 中的图像 1,2 Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 3 中的图像 2,2
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 4 中的图像 1,2 Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 5 中的图像 1,2 Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 6 中的图像 1,2 Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 6 中的图像 2,2
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 7 中的图像 1,2 Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 7 中的图像 2,2
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: 步骤 8 中的图像 1,1
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
终点
4等其他人完成本指南。
wooseok yang
于01/19/21注册
358 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 37
总计 2,055
