跳转到主内容
Logitech Extreme 3D Pro Top button circuit board Replacement
你所需要的
  1. Logitech Extreme 3D Pro Top button circuit board Replacement, Disassembly of the handle: 步骤 1 中的图像 1,1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 3 中的图像 1,2 Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 3 中的图像 2,2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: 步骤 4 中的图像 1,3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: 步骤 4 中的图像 2,3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: 步骤 4 中的图像 3,3
    • Remove the three 7mm Phillips #1 screws from the button board.
    • Remove the button board from the plastic top.
    • When taken apart the plastic buttons can fall out.
  5. Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 5 中的图像 1,2 Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 5 中的图像 2,2
    • Disconnect the cable from the button board.
  6. Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 6 中的图像 1,2 Logitech Extreme 3D Pro Top button circuit board Replacement: 步骤 6 中的图像 2,2
    • Disconnect the smaller cable from the button board.
结论
4等其他人完成本指南。
Emanuel Canela
于01/25/18注册
1,369 声望
创作了7篇指南
团队
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G1
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 2,635
