简介
When moving the joystick, the main spring bends. The spring also keeps the joystick upright. After time, the spring can cause the joystick to sag when not in use. In this situation, replacing the spring will be necessary.
你所需要的
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
6等其他人完成本指南。
5指南评论
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - 回复
Where can I find a replacement spring?
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
In logitech 3d extreme, the middle joystick loosens over time, there is a slight gap when turning it to the right and left. Is there a solution to this?
