跳转到主内容
Logitech Extreme 3D Pro Main Joystick Spring Replacement
你所需要的
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: 步骤 1 中的图像 1,1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 3 中的图像 1,2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 3 中的图像 2,2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: 步骤 4 中的图像 1,1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 5 中的图像 1,3 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 5 中的图像 2,3 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 5 中的图像 3,3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: 步骤 6 中的图像 1,2 Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: 步骤 6 中的图像 2,2
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 7 中的图像 1,2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 7 中的图像 2,2
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 8 中的图像 1,2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 8 中的图像 2,2
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 9 中的图像 1,1
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 10 中的图像 1,1
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: 步骤 11 中的图像 1,1
    • Remove the Spring
    • The spring will be covered in lubricant.
结论
5等其他人完成本指南。
Emanuel Canela
于01/25/18注册
1,297 声望
创作了7篇指南
团队
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G1
4 名成员
创作了7篇指南
6条评论
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - 回复
same question here
Robbert Sprezzatura -
Where can I find a replacement spring?
ande3224@bellsouth.net - 回复
Anyone found a source for replacement springs?
Chandler - 回复
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 36
过去 30 天: 119
总计 11,259
