简介
After a long use the joystick trigger might experience a lack of strength within the trigger's internal spring.
配件
无需配件。
  1. Remove these three Phillips #1 screws:
    • Remove these three Phillips #1 screws:
      • Two 10mm screws.
      • One 7mm screw.
  2. Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
    • Remove the plastic trigger from the joystick.
结论
Emanuel Canela
于2018年01月25日注册
800 信誉积分
创作了7篇指南
团队
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G1
4 名成员
创作了7篇指南
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 19
总计 115
