跳转到主内容
Logitech Extreme 3D Pro Disassembly of the handle
你所需要的
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: 步骤 1 中的图像 1,1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: 步骤 2 中的图像 1,1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: 步骤 3 中的图像 1,2 Logitech Extreme 3D Pro Disassembly of the handle: 步骤 3 中的图像 2,2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
结论
6等其他人完成本指南。
Emanuel Canela
于01/25/18注册
1,297 声望
创作了7篇指南
团队
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G1
4 名成员
创作了7篇指南
2条评论
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - 回复
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 3,406
