简介
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the base portion of the joystick. This will require to have to handle already disassembled.
你所需要的
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Remove the eight 10mm Phillips #1 screws from the bottom.
即将完成!
结论
3等其他人完成本指南。
