跳转到主内容
Logitech Extreme 3D Pro Disassembly of the base
你所需要的
  1. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the handle: 步骤 1 中的图像 1,1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the base: 步骤 2 中的图像 1,1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the base: 步骤 3 中的图像 1,2 Logitech Extreme 3D Pro Disassembly of the base: 步骤 3 中的图像 2,2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the base: 步骤 4 中的图像 1,1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Disassembly of the base: 步骤 5 中的图像 1,3 Logitech Extreme 3D Pro Disassembly of the base: 步骤 5 中的图像 2,3 Logitech Extreme 3D Pro Disassembly of the base: 步骤 5 中的图像 3,3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
结论
3等其他人完成本指南。
Emanuel Canela
于01/25/18注册
1,297 声望
创作了7篇指南
团队
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G1
4 名成员
创作了7篇指南
一条评论
And you didn’t even finish the repair. Thanks for nothing. :(
Jesse James - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 58
总计 3,667
