跳转到主内容
Logitech Extreme 3D Pro Base Button Circuit Board Replacement
你所需要的
  1. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Disassembly of the handle: 步骤 1 中的图像 1,1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 3 中的图像 1,2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Disassembly of the base: 步骤 4 中的图像 1,1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 5 中的图像 1,3 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 5 中的图像 2,3 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 5 中的图像 3,3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Base Button Circuit Board: 步骤 6 中的图像 1,2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Base Button Circuit Board: 步骤 6 中的图像 2,2
    • Remove this wire plug head from this circuit board.
    • Removing this wire frees the base piece to make working on it easier.
  7. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Remove the two 10mm Phillips #1 screws from the button board.
  8. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 8 中的图像 1,2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Lift up the button board.
    • Disconnect the button board.
结论
4等其他人完成本指南。
Emanuel Canela
于01/25/18注册
1,297 声望
创作了7篇指南
团队
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G1
4 名成员
创作了7篇指南
4条评论
What's the dimensions of those switches? Have you managed to find them online? I have 2 faulty ones on my 2005 Extreme 3D Pro
Michael Tyers - 回复
I have just recently changed 6 of them, which shown at step 8 at this guide. Now it works as good as new.
You can find them as “tact switch” (or tactile switch) at online for very cheap prices. Dimensions are milimeter, 6x6 mm and button height is 4.3 mm. i think these are shortest of 6x6 button family.
Search at Google for “6x6x4 tact switch”. For referance:
https://n11scdn1.akamaized.net/a1/1024/e...
Here is how it looks after i changed tem: https://imgur.com/a/DhemkSh
Gökalp Topyan -
Is there anywhere I can get the logic board only. Thanks.
Calvin Lim - 回复
@mikejt86 Thank you for posting this. I have two bad switches, #7 & #12 not working. I have disassembled it to test and strangely find no switching action on any of the switches with my multimeter in continuity mode. They test as if pressing the switch does nothing, which seems odd. Did you test your switches before replacing them? I am more curious than anything at this point.
Jssamp - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 31
总计 3,629
