跳转到主内容
加入维修社区 - 创建账户
Logitech Dual Action disassembly
你所需要的
  1. Logitech Dual Action disassembly, Taking out the screws: 步骤 1 中的图像 1,1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: 步骤 2 中的图像 1,3 Logitech Dual Action disassembly, Opening the controller: 步骤 2 中的图像 2,3 Logitech Dual Action disassembly, Opening the controller: 步骤 2 中的图像 3,3
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: 步骤 3 中的图像 1,1
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
终点
12等其他人完成本指南。
Brian Neuman
于01/20/15注册
1,082 声望
创作了3篇指南
团队
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G4
4 名成员
创作了5篇指南
1指南评论
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 101
总计 7,868
