跳转到主内容
Logitech Dual Action Triggers Repair
你所需要的
  1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: 步骤 1 中的图像 1,1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
  2. Logitech Dual Action Triggers Repair: 步骤 2 中的图像 1,2 Logitech Dual Action Triggers Repair: 步骤 2 中的图像 2,2
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
  3. Logitech Dual Action Triggers Repair: 步骤 3 中的图像 1,1
    • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
  4. Logitech Dual Action Triggers Repair: 步骤 4 中的图像 1,3 Logitech Dual Action Triggers Repair: 步骤 4 中的图像 2,3 Logitech Dual Action Triggers Repair: 步骤 4 中的图像 3,3
    • In the center of the controller, pull upwards on the USB cord.
    • Be careful not to pull hard enough to yank the wires connecting to the logic board.
    • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
  5. Logitech Dual Action Triggers Repair: 步骤 5 中的图像 1,3 Logitech Dual Action Triggers Repair: 步骤 5 中的图像 2,3 Logitech Dual Action Triggers Repair: 步骤 5 中的图像 3,3
    • To remove the triggers, push upwards from the back on them.
    • Once far enough, detach the logic board from the back cover piece and the triggers.
  6. Logitech Dual Action Triggers Repair: 步骤 6 中的图像 1,2 Logitech Dual Action Triggers Repair: 步骤 6 中的图像 2,2
    • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
    • Look at the second picture to see where the wires go.
  7. Logitech Dual Action Triggers Repair: 步骤 7 中的图像 1,3 Logitech Dual Action Triggers Repair: 步骤 7 中的图像 2,3 Logitech Dual Action Triggers Repair: 步骤 7 中的图像 3,3
    • Unscrew the screw on the trigger to remove the back cover.
    • Once removed, carefully pull the back cover off.
  8. Logitech Dual Action Triggers Repair: 步骤 8 中的图像 1,1
    • The 3 wires are soldered into the 3 spots circled on the picture.
    • You can now fasten the wire into the right spot on the trigger piece.
结论
4等其他人完成本指南。
Brian Neuman
于01/20/15注册
893 声望
创作了3篇指南
团队
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G4
4 名成员
创作了3篇指南
2条评论
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - 回复
Where can I get conductive pads for this?
Ginga - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 122
总计 8,949
