简介
If the joystick on your Logitech Dual Action controller isn't working properly, refer to the guide to walk you through how to replace the joystick on your Logitech Dual Action controller.
The joystick is an essential part of any controller. A faulty joystick will result in difficulty navigating any software you may encounter where you will need the joystick.
Ensure your controller is disconnected from the power source before beginning your replacement.
你所需要的
To get into the controller, you will need to unscrew the 7 screws on the back.
You will have to remove the bottom oval sticker to reveal the screw marked with orange.
With the screws removed, turn the controller upside down and separate the front end from the back end.
With the case off, the joysticks can be removed by pulling them upward.
To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
Where can we find the replacement Analogue Sticks
shivam sah - 回复
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a> foe complete network innfoemarion on the website
14等其他人完成本指南。
5条评论
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - 回复
If you need sticks look for small holed ones like these.
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
