跳转到主内容
Logitech Dual Action Joystick Replacement
你所需要的
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: 步骤 1 中的图像 1,1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: 步骤 2 中的图像 1,3 Logitech Dual Action Joystick Replacement, Opening the controller: 步骤 2 中的图像 2,3 Logitech Dual Action Joystick Replacement, Opening the controller: 步骤 2 中的图像 3,3
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: 步骤 3 中的图像 1,2 Logitech Dual Action Joystick Replacement, Replacing the joystick: 步骤 3 中的图像 2,2
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
终点
24等其他人完成本指南。
Brian Neuman
于01/20/15注册
1,082 声望
创作了3篇指南
团队
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 的会员
USFT-REMMELL-W15S7G4
4 名成员
创作了5篇指南
5指南评论
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - 回复
will the buttons still work if you put it all back?
Atsuku - 回复
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - 回复
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 46
过去 30 天: 197
总计 12,979
