跳转到主内容
Logitech Dexxa Joystick Secondary Button Cap Replacement
你所需要的
  1. Logitech Dexxa Joystick Secondary Button Cap Replacement, Trigger Cap: 步骤 1 中的图像 1,3 Logitech Dexxa Joystick Secondary Button Cap Replacement, Trigger Cap: 步骤 1 中的图像 2,3 Logitech Dexxa Joystick Secondary Button Cap Replacement, Trigger Cap: 步骤 1 中的图像 3,3
    • Unplug your Joystick before use.
    • Remove the three 2 mm screws on the right panel.
    • Remove the right cover panel
    • Open the joystick
    • Open gently to prevent the joystick from falling apart
  2. Logitech Dexxa Joystick Secondary Button Cap Replacement: 步骤 2 中的图像 1,2 Logitech Dexxa Joystick Secondary Button Cap Replacement: 步骤 2 中的图像 2,2
    • Remove the top panel
    • Remove the button cap
  3. Logitech Dexxa Joystick Secondary Button Cap Replacement, Secondary Button Cap: 步骤 3 中的图像 1,3 Logitech Dexxa Joystick Secondary Button Cap Replacement, Secondary Button Cap: 步骤 3 中的图像 2,3 Logitech Dexxa Joystick Secondary Button Cap Replacement, Secondary Button Cap: 步骤 3 中的图像 3,3
    • Unscrew the two silver 1 mm screws
    • Remove the circuit board
    • Push the purple secondary button cap out from its slot
结论
Addison
于08/30/19注册
3,081 声望
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 132
