跳转到主内容
Logitech Circle Speaker Replacement
你所需要的
  1. Logitech Circle Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Logitech Circle Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: 步骤 3 中的图像 1,2 Logitech Circle Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: 步骤 4 中的图像 1,2 Logitech Circle Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: 步骤 5 中的图像 1,2 Logitech Circle Speaker Replacement: 步骤 5 中的图像 2,2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: 步骤 6 中的图像 1,2 Logitech Circle Speaker Replacement: 步骤 6 中的图像 2,2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: 步骤 7 中的图像 1,1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
结论
Emma Cochran
于09/28/17注册
110 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 354
