跳转到主内容
修复你的物品
维修的权力
商店
  1. Na parte inferior da WebCam, remova os adesivos nos dois lados Na parte inferior da WebCam, remova os adesivos nos dois lados
    • Na parte inferior da WebCam, remova os adesivos nos dois lados
    If you remove the rubber stickers and don’t see any screws underneath, it’s because there are actually two layers of stickers. The top sticker is the rubber that you can see, and underneath it is a plastic sticker. Sometimes they come away together, sometimes you will need to pry away the plastic sticker after first removing the rubber.
    drspod - 回复
    Existem dois adesivos em ambos os lados.
    Jose Gustavo Abreu Murta - 回复
    You can heat the stickers with a lighter , so they come off very easy .
    kar bouter - 回复
  2. Remova os quatro parafusos Philips.
    • Remova os quatro parafusos Philips.
    • Pressione nos buracos, para destravar as tampas laterais.
    what screwdriver size did you use? I stripped mine and it’s the smallest screwdriver I already get it’s the PH000 philips size
    xkntgnzn - 回复
    The screw may be easily removed with appropriate screwdriver.
    The dimensions must be match! PH1 I think…
    Comprei 3 kits de chaves e nenhuma tirou esse bendito parafuso, amanhã levarei a camera junto na hora da compra
    renanzinho.castro - 回复
    Renanzinho, se usou a chave incorreta pode ser que tenha danificado a cabeça do parafuso. Para mim, foi super fácil a remoção desses parafusos. Use a chave tipo PH1.
  3. Após retirar as tampas laterais, solte todos os oito parafusos Philips. Após retirar as tampas laterais, solte todos os oito parafusos Philips.
    • Após retirar as tampas laterais, solte todos os oito parafusos Philips.
    The inner four of these screws can sometimes be extremely tight. They will easily strip if you are unable to get them to turn. I had one screw that I was unable to remove so I had to break that screw fixture on the clear plastic cover. Once you can remove the clear plastic you no longer need to worry about these screws. If they are stuck they will just stay in the black plastic support as they only hold down the clear plastic.
    drspod - 回复
    Use the correct screw driver. So easy to unscrew.
    These screws are a different size to the ones in step 2.
    Michael Van den Acker - 回复
    The strength of a thousand locomotives will not allow you to remove the side covers even if unclipped. Be prepared to break either the side covers or your fingers.
    michaldobrzynski - 回复
    Michal, of course, you must gently unlatch the side covers to remove them!
    For me, it was easy…
    Jose:
    I am 6 foot 3 with large strong hands to match. In the end, it took channel locks gripping the correct screwdriver to get the leverage to make the first few turns.
    The next time I get a flat, I would like to call on you to lift the care while I change the wheel.
    For those who come after us, prepare to use deadly force on these four small screws.
    Robert
    Robert McCullough - 回复
    Robert McCullough,
    “Give me a place to stand and with a lever I will move the whole world.
    Archimedes
  4. Remova a tampa cristalina da lente. Remova os cinco parafusos Philips do suporte de metal. Remova as borrachas dos dois microfones (uma de cada lado).
    • Remova a tampa cristalina da lente.
    • Remova os cinco parafusos Philips do suporte de metal.
    • Remova as borrachas dos dois microfones (uma de cada lado).
    Don’t forget to remove the screw just below the camera lens as well.
    You must do this at previous step.
    Unfortunately you skipped mentioning it in the previous step when removing the 4 metal bracket support screws.
    Fernando Navarette -
  5. Cuidadosamente remova os suportes metálicos da base da webcam.
    • Cuidadosamente remova os suportes metálicos da base da webcam.
  6. Cuidadosamente remova a base do suporte de plástico. Solte os três parafusos que prendem o circuito eletrônico. Cuidadosamente remova a base do suporte de plástico. Solte os três parafusos que prendem o circuito eletrônico.
    • Cuidadosamente remova a base do suporte de plástico. Solte os três parafusos que prendem o circuito eletrônico.
    The directions forgot to mention to remove the screw directly below the lens before this step.
    Max Watson - 回复
    Max, you skipped step 4 where I inform you of the need to remove that screw bellow the lens.
  7. Desconecte o conector do cabo USB.
    • Desconecte o conector do cabo USB.
    BE VERY CAREFUL not to apply too much force when trying to remove this header. The socket will easily come away from the PCB and then you will need to solder it back on again. Mine was extremely tight and separated from the PCB.
    drspod - 回复
    Is it a PH 1.25 or PH 2.0 connector? thanks.
    Abdiel Adams - 回复
  8. Remova o circuito eletrônico.
    • Remova o circuito eletrônico.
  9. Solte o clip que prende o suporte do cabo. Puxe esse suporte do cabo para fora da câmera. Solte o clip que prende o suporte do cabo. Puxe esse suporte do cabo para fora da câmera.
    • Solte o clip que prende o suporte do cabo. Puxe esse suporte do cabo para fora da câmera.
  10. Imagens frontal e traseira da placa de circuito eletrônico da webcam. Imagens frontal e traseira da placa de circuito eletrônico da webcam.
    • Imagens frontal e traseira da placa de circuito eletrônico da webcam.
  11. O problema da webcam era o cabo partido, na parte traseira da câmera. Cortei a parte com defeito e refiz as ligações com solda e isolei com tubos (espaguetes) termorretráteis.
    • O problema da webcam era o cabo partido, na parte traseira da câmera. Cortei a parte com defeito e refiz as ligações com solda e isolei com tubos (espaguetes) termorretráteis.
    Is the silver one the shield of usb cable or something else?
    Abdiel Adams - 回复
    The aluminum foil is also a shield.
  12. O cabo recuperado foi montado na câmera. Revesti-o com uma fita crepe. Câmera testada: OK !
    • O cabo recuperado foi montado na câmera. Revesti-o com uma fita crepe. Câmera testada: OK !
    • Remonte a câmera seguindo o procedimento na ordem inversa.
结论
Para remontagem de seu dispositivo, siga estas instruções na ordem inversa.
17等其他人完成本指南。
于2010年07月06日注册
3,482 信誉积分
创作了7篇指南
Excellent! Helped me figure out how to get the base off to mount it to an ikea worklamp as a hacky boom.
Cory Elsmore - 回复
thanks for an excellent guide . I am now more positive that it is something I can perform now. Many thanks
Graham Klaer - 回复
im having trouble releasing the 4 screws on step 3!!! the screw driver keeps slipping and i’ve tried a few and another webcam…
Dojo Mats - Sunny - 回复
Dojo, Use the correct screw driver. So easy to unscrew.
If you have damaged the screw head, you can use pliers. You will need to replace the damaged screws.
They’re quite tight screws on the ones I’ve worked on . Super, super soft metal too, very easy to strip out.
Catherine Mateo -
Many thanks for this excellent guide!! Helped me to repair my camera
Samuel Anaya - 回复
Not all the webcams are as quality as Logitech HD Pro Webcam c920. Because this is rich its specifications and full of features. Ordinary or the built-in webcams are just ways of calling at high definition resolution with low framerate.
Frank Edward - 回复
Suddenly c920 stopped working..i thought wire is broken..but after opening up..no broken wire is visible..what must be the problem and how to solve?..pls help
pankaj meshram - 回复
Pankaj, you must measure continuity of wires of cable with multimeter.
In my case, I was replacing the damaged cable with a new cable I ordered from eBay. That requires de-soldering the black wire on the PCB and soldering the new one in place. Those who venture into that task should know that (a) the solder tab on the replacement cable is extremely delicate, so it is important to fully remove the old solder with a solder-sucker to put the tab in place, and (b) the newly-soldered wire must be oriented parallel to the camera, because otherwise, it will mechanically interfere with re-assembly. Great guide though! THANKS!
Bob Sneed - 回复
Thanks for taking the time to document this procedure. Great instructions!!
K.C. Shoemaker - 回复
Can the crystal cover be separated? Mine shipped with dirt in between the layers
Quentinlowery - 回复
Hi Quentim,
I Think the crystal cover is glued.
For years i’d been listening to salesmen in stores like Best Buy who told me that webcams are made to be replaced; not repaired. Thank you so much for enlightening me and saving me the $150 that Amazon wants for a C922. I repaired my C920 and it works like the day i bought it! It didn’t cost me a penny. Thank YOU!
DJ Gicomeng - 回复
Thanks for your work on this guide Jose, much appreciated.
Seems the cables in these commonly break near where the cable joins the body.
Catherine Mateo - 回复
Is it possible to rotate the camera lens module 90’? I’m trying to mount the camera vertically, but still have the picture come out in the normal orientation. I realize I could rotate the image in the software, but this tends to skew the aspect ratio.
Dave Kerry - 回复
Great Article! Saved me $$$.
Bill Noble - 回复
添加评论
浏览统计数据:
过去的24小时: 26
过去的7天: 160
过去的30天: 821
总计 17,378
