简介
Follow this guide if your phone's logic board needs to be replaced.
你所需要的
Face the phone's back cover towards you. Press the oval-shaped button located at the bottom of the cover.
While holding this button, slide the back cover off. This should expose the battery.
Identify the orange strip attached to the upper right hand corner of the logic board.
Detach this strip by pulling it off of the logic board but not off the phone itself. This will then enable you to pull your logic board off.
Pay attention to the orientation of the logic board as you will use this same orientation when you insert the new logic board.
