跳转到主内容
Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement
你所需要的
  1. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Disconnect the spark plug: 步骤 1 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Disconnect the spark plug: 步骤 1 中的图像 2,2
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Pull the spark plug connector straight off of the spark plug.
  2. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the air filter cover: 步骤 2 中的图像 1,1
    • Unscrew the bolt securing the air filter cover
  3. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 3 中的图像 1,3 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 3 中的图像 2,3 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 3 中的图像 3,3
    • Rotate the air filter cover 90° and lift it straight up to remove it.
  4. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle cable: 步骤 4 中的图像 1,1
    • Use a Phillips #2 screwdriver to loosen the screw securing the throttle cable clamp.
  5. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 5 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 5 中的图像 2,2
    • Use a pair of needle nose pliers to lift the throttle cable out of its slot on the throttle body.
  6. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 6 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 6 中的图像 2,2
    • Slide the throttle cable out of its clamp.
  7. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 7 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 7 中的图像 2,2
    • Use a pair of flush cutters to cut through the zip tie securing the throttle cable to the auger and remove it.
    • Repeat this step for all seven zip ties along the throttle cable.
  8. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 8 中的图像 1,1
    • Use a flathead screwdriver to loosen the throttle cable end clamp.
  9. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 9 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 9 中的图像 2,2
    • Remove the end of throttle cable from the clamp.
  10. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 10 中的图像 1,1
    • Loosen the red screw clamping the throttle cable in the holder on the handle.
  11. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 11 中的图像 1,1
    • Remove the throttle cable from its holder on the handle.
  12. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 12 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 12 中的图像 2,2
    • Slide the throttle cable out of the braided wiring sleeve.
  13. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle lever: 步骤 13 中的图像 1,3 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle lever: 步骤 13 中的图像 2,3 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle lever: 步骤 13 中的图像 3,3
    • The throttle lever is held in place by a flared rivet. You will need to replace this rivet with a new one, and re-flare it, during reassembly.
    • Use needle nose pliers to bend the flared end of the rivet inward to straighten it.
  14. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 14 中的图像 1,1
    • Use a pin punch and a hammer to tap the rivet out of the handle.
  15. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 15 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 15 中的图像 2,2
    • Use needle nose pliers to unhook the throttle lever spring from the throttle lever.
  16. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 16 中的图像 1,2 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: 步骤 16 中的图像 2,2
    • Remove the throttle lever.
    • Remove the throttle lever spring.
结论
另外一个人完成了本指南。
Adam O'Camb
于04/11/15注册
209,084 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 765
