跳转到主内容
Lite-On iHAS324 Disc Tray Replacement
你所需要的
  1. Lite-On iHAS324 Disc Tray Replacement, Chassis: 步骤 1 中的图像 1,2 Lite-On iHAS324 Disc Tray Replacement, Chassis: 步骤 1 中的图像 2,2
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Disc Tray Replacement: 步骤 2 中的图像 1,3 Lite-On iHAS324 Disc Tray Replacement: 步骤 2 中的图像 2,3 Lite-On iHAS324 Disc Tray Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Disc Tray Replacement: 步骤 3 中的图像 1,1
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Disc Tray Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Disc Tray Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Disc Tray Replacement: 步骤 6 中的图像 1,1
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Disc Tray Replacement, Disc Tray: 步骤 7 中的图像 1,2 Lite-On iHAS324 Disc Tray Replacement, Disc Tray: 步骤 7 中的图像 2,2
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
结论
另外一个人完成了本指南。
Kayla Culpepper
于03/22/15注册
675 声望
创作了5篇指南
团队
Baylor, Team 5-9, Williams Spring 2015 Baylor, Team 5-9, Williams Spring 2015 的会员
BU-WILLIAMS-S15S5G9
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 1,053
