你所需要的
Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
The tray should then pop open.
Pull out the tray so that it is fully extended.
Push the left tab in and slide the tray out on the left side.
Pull the gray plastic casing on the right side away from the tray.
Slide the right side of the tray out.
在这个步骤中使用的工具:Tweezers$4.99
Take tweezers and remove the black tray belt from the gears carefully.
结论
3等其他人完成本指南。
