简介
If the faceplate has become broken or cracked, you may want to replace it.
配件
无需配件。
  1. Insert an open paper clip into small hole on left side of faceplate. The tray should click open, use your hands to gently extend it fully.
    • Insert an open paper clip into small hole on left side of faceplate.
    • The tray should click open, use your hands to gently extend it fully.
  2. Push in black tabs on left, right and bottom of outer chassis to unhook faceplate. Push in black tabs on left, right and bottom of outer chassis to unhook faceplate. Push in black tabs on left, right and bottom of outer chassis to unhook faceplate.
    • Push in black tabs on left, right and bottom of outer chassis to unhook faceplate.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Pull face plate away from main chassis.
    • Pull face plate away from main chassis.
  5. Locate the two tabs on the underside of the tray cover. Pry the tabs loose and remove cover. Pry the tabs loose and remove cover.
    • Locate the two tabs on the underside of the tray cover.
    • Pry the tabs loose and remove cover.
  6. Remove and replace faceplate.
    • Remove and replace faceplate.
结论
aaa
于2011年10月20日注册
171 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 1,910
