跳转到主内容
简介
Remove the top cover of the optical drive to access the internals and replace any malfunctioning components.
  1. Insert an open paper clip into the small hole on the left side of the faceplate. After the tray opens, extend it fully.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Pull the faceplate away from the main chassis.
    • Pull the faceplate away from the main chassis.
  4. Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
    • Lift the top and bottom chassis straight up in order to remove them.
结论
2等其他人完成本指南。
James Biggs
于2011年10月12日注册
596 信誉积分
创作了3篇指南
团队
Cal Poly, Team 6-5, Regan Fall 2011 Cal Poly, Team 6-5, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G5
2 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 2,374
