跳转到主内容
Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement
你所需要的
  1. Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement, Switch: 步骤 1 中的图像 1,2 Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement, Switch: 步骤 1 中的图像 2,2
    • Unplug the device to avoid injury.
    • Use a Phillips head screwdriver to unscrew the single screw.
    • Hold on to the nut from the other side so you do not lose it.
    • Remove the panel that conceals the switch.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement: 步骤 2 中的图像 1,1
    • Hold on to the red disc with needle nosed pliers, and use the Phillips head screwdriver to remove the disc by pushing down.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement: 步骤 3 中的图像 1,2 Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement: 步骤 3 中的图像 2,2
    • Remove and replace the white switch.
    • Do not be afraid to pull as this takes a bit of force to remove.
结论
Courtney Elliott
于01/14/14注册
375 声望
创作了3篇指南
团队
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 700
