跳转到主内容
Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement
你所需要的
  1. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: 步骤 1 中的图像 1,1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 步骤 2 中的图像 1,3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 步骤 2 中的图像 2,3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 步骤 2 中的图像 3,3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 步骤 3 中的图像 1,1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: 步骤 4 中的图像 1,3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: 步骤 4 中的图像 2,3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: 步骤 4 中的图像 3,3
    • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
    • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
结论
Nick Kaprielian
于01/14/14注册
525 声望
创作了4篇指南
团队
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 671
