跳转到主内容
Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal
你所需要的
  1. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: 步骤 1 中的图像 1,1
    • Turn the device over so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: 步骤 2 中的图像 1,1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: 步骤 3 中的图像 1,2 Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: 步骤 3 中的图像 2,2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
结论
Nick Kaprielian
于01/14/14注册
525 声望
创作了4篇指南
团队
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 590
