跳转到主内容
Linksys WRT54GS v2 Front Case Replacement
你所需要的
  1. Linksys WRT54GS v2 Front Case Replacement, Front Case: 步骤 1 中的图像 1,1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Front Case Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Front Case Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Front Case Replacement: 步骤 4 中的图像 1,1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
结论
另外一个人完成了本指南。
Allian Roman
于10/12/11注册
276 声望
创作了5篇指南
团队
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,099
