跳转到主内容
简介
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
配件
没有特定配件。
  1. Unfold the antennas straight away from the device.
    • Unfold the antennas straight away from the device.
  2. Remove the black caps from the antennas by pulling them away from the device. Remove the black caps from the antennas by pulling them away from the device. Remove the black caps from the antennas by pulling them away from the device.
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Unscrew each of the antennas from the wireless device. Unscrew each of the antennas from the wireless device. Unscrew each of the antennas from the wireless device.
    • Unscrew each of the antennas from the wireless device.
  4. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  5. Using a bit of force, remove the blue plastic case. Using a bit of force, remove the blue plastic case.
    • Using a bit of force, remove the blue plastic case.
  6. To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance. Pull the top piece upwards and away from the bottom to remove.
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  7. Locate the 2 M2.5x6mm screws that attach the motherboard to the back case. Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  8. Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
结论
3等其他人完成本指南。
Aaron Brown
于2011年10月11日注册
163 信誉积分
创作了2篇指南
团队
Cal Poly, Team 17-7, Regan Fall 2011 Cal Poly, Team 17-7, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G7
4 名成员
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 2,983
