跳转到主内容
Linksys WAP54g Top Casing Replacement
你所需要的
  1. Linksys WAP54g Top Casing Replacement, Top Casing: 步骤 1 中的图像 1,1
    • Power down and unplug the device.
  2. Linksys WAP54g Top Casing Replacement: 步骤 2 中的图像 1,1
  3. Linksys WAP54g Top Casing Replacement: 步骤 3 中的图像 1,1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Top Casing Replacement: 步骤 4 中的图像 1,1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Top Casing Replacement: 步骤 5 中的图像 1,1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Top Casing Replacement: 步骤 6 中的图像 1,1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Top Casing Replacement: 步骤 7 中的图像 1,2 Linksys WAP54g Top Casing Replacement: 步骤 7 中的图像 2,2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Top Casing Replacement: 步骤 8 中的图像 1,2 Linksys WAP54g Top Casing Replacement: 步骤 8 中的图像 2,2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
结论
From here you can take apart the rest of the router apart by following subsequent guides.
另外一个人完成了本指南。
Derek Myers
于10/04/11注册
288 声望
创作了5篇指南
团队
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G21
5 名成员
创作了12篇指南
一条评论
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
Philippe Gabriel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,500
