跳转到主内容
Linksys WAP54g Bottom Casing/Motherboard Replacement
你所需要的
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: 步骤 1 中的图像 1,1
    • Power down and unplug the device.
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 2 中的图像 1,1
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 5 中的图像 1,1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 6 中的图像 1,1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 7 中的图像 1,2 Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 7 中的图像 2,2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 8 中的图像 1,2 Linksys WAP54g Bottom Casing/Motherboard Replacement: 步骤 8 中的图像 2,2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: 步骤 9 中的图像 1,2 Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: 步骤 9 中的图像 2,2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
结论
After the motherboard is isolated component level repairs can be made.
2等其他人完成本指南。
Mathew Fuller
于10/04/11注册
146 声望
撰写一个指南
团队
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G21
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,582
