当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Make sure the antennas are in a straight position, not bent, to remove the black casing.
Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
Repeat these steps for other antenna.
取消:我没有完成这个指南。
2等其他人完成本指南。
与7其他贡献者
于10/04/11注册
288 声望
创作了5篇指南
徽章: 12
+ 9更多徽章
CPSU-MANESS-F11S21G21
5 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 13
总计 2,574
