跳转到主内容
Linksys WAP 11 Outer Case Replacement
你所需要的
  1. Linksys WAP 11 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Be sure the ethernet and power cables are disconnected from the device.
    • You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
  2. Linksys WAP 11 Outer Case Replacement: 步骤 2 中的图像 1,3 Linksys WAP 11 Outer Case Replacement: 步骤 2 中的图像 2,3 Linksys WAP 11 Outer Case Replacement: 步骤 2 中的图像 3,3
    • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
    • Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
    • This will reveal two small Phillips-head screws. Remove them.
    • Keep these two screws together.
  3. Linksys WAP 11 Outer Case Replacement: 步骤 3 中的图像 1,2 Linksys WAP 11 Outer Case Replacement: 步骤 3 中的图像 2,2
    • Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
  4. Linksys WAP 11 Outer Case Replacement: 步骤 4 中的图像 1,1
    • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • When removing the base, do not damage the wires that are attached to the device.
  5. Linksys WAP 11 Outer Case Replacement: 步骤 5 中的图像 1,1
    • This is what the device looks like when it is fully opened.
结论
Joe M
于10/12/11注册
159 声望
创作了3篇指南
团队
Cal Poly, Team 3-17, Regan Fall 2011 Cal Poly, Team 3-17, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G17
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,066
