跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If the network port is faulty, the device can not send or receive information through a wired connection. Replacing the network port may resolve communication issues.
  1. Be sure the ethernet and power cables are disconnected from the device.
    • Be sure the ethernet and power cables are disconnected from the device.
    • You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
  2. To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers. Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot.  Once you are hooked behind the boot, pull outwards. This will reveal two small Phillips-head screws.  Remove them.
    • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
    • Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
    • This will reveal two small Phillips-head screws. Remove them.
    • Keep these two screws together.
  3. Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other. This requires significant amount of force.
    • Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
  4. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • When removing the base, do not damage the wires that are attached to the device.
  6. This is what the device looks like when it is fully opened.
    • This is what the device looks like when it is fully opened.
  7. At this point, you may want to remove the antenna leads as well. Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
    • At this point, you may want to remove the antenna leads as well.
    • Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
    • Once the screws are removed, your motherboard will separate from the housing.
    • Keep these three screws together and separate from the outer case screws.
  8. Ifixit soldering guide Soldering and desoldering have the potential for harm, always wear propper eye protection and other personal protective equipment while performing either action!
    • Ifixit soldering guide Soldering and desoldering have the potential for harm, always wear propper eye protection and other personal protective equipment while performing either action!
    • Turn the main circuit board around and using a soldering iron and desoldering wick desolder the 12 pins that secure the port to the main board.
  9. Using a pair of needle nose pliers squeeze the two black plastic clips that secure the network port to the board together and then push them through. Replace with a new network port and reassemble in reverse order.
    • Using a pair of needle nose pliers squeeze the two black plastic clips that secure the network port to the board together and then push them through.
    • Replace with a new network port and reassemble in reverse order.
结论
Joe M
于2011年10月12日注册
156 信誉积分
创作了3篇指南
团队
Cal Poly, Team 3-17, Regan Fall 2011 Cal Poly, Team 3-17, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G17
5 名成员
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 684
