拆解
This wireless router stopped working, so I wanted to take a look at it's innards.
这个拆解是不是维修指南。 要维修你的的Linksys BEFW11S4,请使用我们的维修手册。
Waiting to be disassembled...
Remove antennas.
Remove nuts and washers around antenna connectors.
Push in antenna connectors.
Remove feet (with flat-head screwdriver, fingernails, etc).
Unscrew the screws.
Pull apart blue front from black back with a LOT of force.
Slide and pull up bottom. (Make sure the antenna connectors get through.)
Twist and pull out antenna connector feeds.
Pull up RF shield from motherboard.
Unscrew the motherboard from the bottom.
Push the motherboard forward (as in this picture) to unlatch it from the bottom.
Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
Push the card forward to deattach the pins.
Remove the card from the metal holdster.
Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
Macronix 29F040QC-90
ISSI IS41C16100S-50K
SAMSUNG ARM S3C4510X01-QERO
RMC RTL8019AS
Bothhands FB2022
Bothhands 40ST1041E
Kendin KS8995. Kendin has since been bought by Micrel.
Enjoy!
与5其他贡献者
于04/18/10注册
65 声望
撰写一个指南
徽章: 1
what is that card inside this router
hartiTube - 2016年7月31日 回复
Thank you. I accomplished this task. Except my antenna wires were soldered to the board.
Darren - 2016年9月18日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 9,034
